5 members (Niels V, Phak1, MNSmith, 2 invisible), 77 guests, and 4 robots.
Topics128,180
Posts1,057,141
Members48,463
#3682 02/10/2004 4:09 AM
Aloha nui loa, i'm sure this has been answered before but didn't see anything in the archives so: My'51 is slowly leaking gear oil from the tranny, down the torque tube and into the rear end, I've just gone on a schedule of draining the rr end and re-filling the trans, someone mentioned the fix, some kind of bushing(?) with a funny name, and said it wasn't easy and if it has been done once already your kinda dead in the water. Any help and/or suggestions? Many Mahalo's
"Okie" bushing .
Try Jim Carter , I have had them from him several times .
Cheers Dusty
Kimo, be sure you keep that transmission oil up utill you install the Okie bushing. You don't want that tranny to run dry. That could cause major problems.
