2 members (UtahYork, stlcardinalsguy), 40 guests, and 3 robots.
Topics128,026
Posts1,055,404
Members48,422
#367634 01/29/2008 9:16 PM
Apprentice
Apprentice
I have found a deal that would give me the rear end from a 1985 3/4 ton burban. can anyone advise on putting it in a 47 3100? also it has a 350 csb and trubo 350 trans. would it be worth using as a donor?
awelchel #367648 01/29/2008 9:38 PM
I am guessing that it would be a little too wide for the 47.You also want to check the gear ratio.The 350 SB and 350 Turbo should workout just fine.
dale937 #367656 01/29/2008 9:49 PM
I also agree it's too wide and won't have a desirable gear ratio.
I don't think you would want different bolt patterns for front and rear either.
Steve
'49 3800
'52 3600
'57 3100
Ghostrider #367673 01/29/2008 10:04 PM
Apprentice
Apprentice
so the engine and tranny combo would be fine with the stock r/e?
awelchel #367696 01/29/2008 10:49 PM
Riding in the Passing Lane
Wrong. The stock rear end is closed drive shaft & is geared too low. You will need to make some changes but the 3/4 ton is too big & heavy & uses 8 bolt wheels.
1972 Chevy c10 Cheyenne Super
awelchel #367697 01/29/2008 10:49 PM
Your torque tube rearend is not compatible with the turbo 350.
You need to convert to open driveline...
Steve
'49 3800
'52 3600
'57 3100
awelchel #367698 01/29/2008 10:50 PM
I would look at replacing the orig rear with something a little heaver and with better gears. I assume you have a 47 2nd which means you will need something around 62" wide. Good luck with the tape measure.
~Jim
BIG CHEVY 3600 #367703 01/29/2008 11:04 PM
Apprentice
Apprentice
any suggestions on what to pull a r/e out of?
awelchel #367944 01/30/2008 6:00 AM
Late 70s early 80s Camaro/Firebird 10 bolt and there are 12 bolt rears that will fit as well. You will need to move the spring perches.
Check the archives here and you will find a lot of posts on this subject.
~Jim
BIG CHEVY 3600 #367986 01/30/2008 8:27 AM
The '63-'67 Chevy truck rearends are a nice choice, I have one with a 3.07 gear set and six bolt wheels that is 62" wide going into my truck. You just need to weld on new spring perches.
Paint & Body Shop moderator
4ontheFloor #368591 01/31/2008 9:55 AM
How about a 55-6-7 Chev car rear end, it already has perches,could it be a good width?
KillerKnight #368863 01/31/2008 10:44 PM
Finding early model rears in a junk yard will be difficult. Check on the archive here. There are web sites that list all the different options (vehicles) and their widths.
~Jim
