| | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36767 03/03/2003 2:04 AM | Joined: Feb 2003 Posts: 45 Member | | Member Joined: Feb 2003 Posts: 45 | i just bought a 1950 5 window. the pick up is disassembled. my question is how many lugs is it supposed to have if it's a 1/2 ton chassis??? thanx
1950 1/2 ton 3 window
#36768 03/03/2003 2:31 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | |
#36769 03/03/2003 2:47 AM | Joined: Feb 2003 Posts: 45 Member | | Member Joined: Feb 2003 Posts: 45 |
#36770 03/03/2003 2:53 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | 24,,,,, 6 for each wheel (6-lugs if it is still stock equipped running gear)
#36771 03/03/2003 3:01 AM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | 25! six for each wheel and one for the spare.  | | |
#36772 03/03/2003 8:03 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I now know where i can get a quick spare tire held on by only one loose nut,,,,OR was that the one behind the wheel  :p :p
