| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 21 Apprentice | | Apprentice Joined: Jan 2008 Posts: 21 | I have found a deal that would give me the rear end from a 1985 3/4 ton burban. can anyone advise on putting it in a 47 3100? also it has a 350 csb and trubo 350 trans. would it be worth using as a donor? | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I am guessing that it would be a little too wide for the 47.You also want to check the gear ratio.The 350 SB and 350 Turbo should workout just fine. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I also agree it's too wide and won't have a desirable gear ratio. I don't think you would want different bolt patterns for front and rear either. | | | | | Joined: Jan 2008 Posts: 21 Apprentice | | Apprentice Joined: Jan 2008 Posts: 21 | so the engine and tranny combo would be fine with the stock r/e? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Wrong. The stock rear end is closed drive shaft & is geared too low. You will need to make some changes but the 3/4 ton is too big & heavy & uses 8 bolt wheels. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Your torque tube rearend is not compatible with the turbo 350. You need to convert to open driveline... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I would look at replacing the orig rear with something a little heaver and with better gears. I assume you have a 47 2nd which means you will need something around 62" wide. Good luck with the tape measure.
~Jim
| | | | | Joined: Jan 2008 Posts: 21 Apprentice | | Apprentice Joined: Jan 2008 Posts: 21 | Thanks, any suggestions on what to pull a r/e out of? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Late 70s early 80s Camaro/Firebird 10 bolt and there are 12 bolt rears that will fit as well. You will need to move the spring perches. Check the archives here and you will find a lot of posts on this subject.
~Jim
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The '63-'67 Chevy truck rearends are a nice choice, I have one with a 3.07 gear set and six bolt wheels that is 62" wide going into my truck. You just need to weld on new spring perches.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | How about a 55-6-7 Chev car rear end, it already has perches,could it be a good width? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Finding early model rears in a junk yard will be difficult. Check on the archive here. There are web sites that list all the different options (vehicles) and their widths.
~Jim
