5 members (Otto Skorzeny, Phak1, 66flea, Ridgeback, 1 invisible), 115 guests, and 0 robots.
Topics128,162
Posts1,056,944
Members48,458
#36745 04/05/2005 1:03 PM
It was just before Christmas when Four on the Floor from this site ,who was visiting family in NY,helped me drag the 302 GMC bare block and parts into my cellar for assembly after the machine shop drained my wallet.
It's been up and running for a week or so,started on one revolution,the only problem was a minor coolant leak,easy to fix once I took the water pump on and off 3 times,lol.
The Venolia 9.25 compression forged pistons are quiet even when the engine is cold,the cam I had ground to my own specs by Colt Cams in Canada gives a smooth powerband from 1000-4500 rpm,the cam is really quiet,almost no tappet noise at all.Even my home made tube headers don't leak!!!Some lucky quessing on my part grin
The swap to GMC 302 from a Chevy 261 was easy.moved the radiator foward about an inch and a half by modifying the radiator side brackets,and welded up a front motor mount plate to reposition the mount about an inch foward,everything else fit like it was designed for the swap.
The engine is very smooth,idles with a moderate lope at 800 rpm,and runs very strong.I don't really break in engines so to speak,I just start em and drive like usual.
An interesting note,the 390 Holley 4bbl that was on the 261,went directly on this GMC engine.Now the Clifford manifold on the 261 and the Patrick's designed 4 bbl intake on this 302 are a slightly different design,both are water heated.On the GMC,I had to jet down the primary a few sizes to get the proper part throttle mixture.And although the GMC has higher actual compression nad the same distributer advance curve and full timing advance more or less that the 261,the 302 doesn't ping on 93 Sunoco like the 261 did sometimes.I guess the GMC head design is more detonation resistant,besides breathing better.
[img]http://img.villagephotos.com/p/2003-1/95040/TPULK-truck002.jpg[/img]
#36746 04/05/2005 2:28 PM
Very nice Tony--you make it look easy--surprised about the fuel-- I thought you wud require the hi dollar stuff. Green truck even looks gud. Primer paint sure has held up well on that race truck.
Buzz'n Half Dozen
#36747 04/05/2005 6:09 PM
Tony, that is BAD ARSE!
So, in a nutshell, you are happy and very pleased with the results?
It looks really awesome. Is that an original, modified oil bath or did you make that too?
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#36748 04/05/2005 6:14 PM
Yeah Buzz, it's all a piece of cake,just ignore the BS and what remains is what ya have to do.
I bought that aircleaner on Ebay for pocketchange,it's some universal 2bbl paper filter thing.I cut out the bottom,formed a piece of sheetmetal to fit the 5 inch Holley opening,got a 10 inch diameter by 4 inch high K&N inside.On my wife's 51 truck, I gutted a stock oil bath that had a rotted bottom,made a similar adapter to fit a Holley,fitted a K&N to that one also.
#36749 04/05/2005 6:14 PM
Tony, nice job,truck and engine looks great,,regards..Fred
Redryder pix
My Hotrod
#36750 04/05/2005 7:02 PM
MORE PICTURES. Is this where you put that 4spd Sag/overdrive? If so, is that working as expected?
Gear spacing wise and so on.
'67 GMC 3/4 292 4spd
