1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36738 05/30/2003 2:21 AM | Joined: Jun 2002 Posts: 53 Member | | Member Joined: Jun 2002 Posts: 53 | Hello, I need someones help! I am searching for parts for my 59 GMC Napco 1/2ton p/u. This is what I need; Front diff. inner axle shaft seals, steering ball seals, steering ball gaskets, spindle bushings.
Rear diff.(1960-62 Chevy Dana 1/2ton), need rear axle seals and cover gasket for this.
I had no luck in finding any of these parts. Is there anyone out there that can help me?
Thank you very much, Bob | | |
#36739 05/30/2003 4:35 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | good luck w/ that one Bob!! original NAPCO parts = lotsa searchin - start here for NAPCO specific stuff - the rear parts should be available at NAPA, if you've one nearby that has real parts guys mannin the decks Bill | | |
