| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i will be as brief as possible i am pulling the 52 235 out of my 46 2 ton i have a 235 casting number 3769716 inliners says its a 60 235 truck motor. after searching on the forum i have decided to go with the water pump relocation plate (i could make my own if i had the dims) a 54 216 waterpump with 3\8 pulley the 60 235 har. bal. that has a 3\8 pulley and an alternator again 3\8 pulley. please advise me on a fan and fan speed will the above set up work for me?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There was no 1954 216 engine. Maybe you are referring to a 1954 261 water pump?
Nonetheless, I think the 1954/55 235/261 water pumps were similar to the older 216 water pumps.
I am also interested in seeing what people say about the fan shroud diameter in a set-up as you describe. I'll be doing what you describe on a 1960 261 with the water pump adapter plate and an older style water pump with the 53-55 3/8" pulley, and a 1954 3/8" harmonic balancer. I'll probably use the 3/8" pulley and fan off a 1954 water pump.
Tim | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | yes i mean 54 235. old style pump with 3/8 pulley. im not going to run a shroud i just dont want to over speed the fan and water pump | | |
