4 members (Ricks Big Dump, Donf, Peggy M, 1 invisible), 148 guests, and 3 robots.
Topics128,086
Posts1,056,101
Members48,434
#366740 01/27/2008 11:51 PM
I have a pair of saddle tanks from a 1985 C-10. I can place one under the bed beween the driveshaft and the frame. I plan to use the stock filler location in the side of the cab. Maybe I'll get creative and put a filler door on the cab.
I am going to buy a new sending unit and some have two outlets and some have three. I am using a 235 and T-5. What are the extra outlets for? One is likely a return for fuel injection or throttle body so I need a two outlet version. Where would the second outlet go? Is it a vent? How is it "plumbed"?
thanks,
1946 Chevy Half Ton
('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS)
1976 Margay Panther X, MC91B
It is a vent and should be run a little higher than your inlet if possible.
~Jim
