2 members (MickeyP, Charles in CA), 38 guests, and 9 robots.
Topics128,012
Posts1,055,311
Members48,419
#366489 01/27/2008 4:48 PM
I have a 1947 Chevy 3/4 ton pickup (late series). I know that the original motor has been replaced with a newer one (from a 1965, I THINK). It has been sitting for about 10 years and we want to get it running again. It will either need a rebuild or a short block. Anyone know of a good place to find a rebuilt short block? Like I said, I THINK it is a 65 230 or 235 (have to check numbers to be sure).
Dachshund #366510 01/27/2008 5:26 PM
I usewd to have the casting number link but now it don't work.
try looking up moretech and search there for the casting numbers.
Dachshund #366511 01/27/2008 5:28 PM
Post a description of the valve cover bolt pattern (and number of bolts that hold the valve cover down) and someone will be able to give a closer guess at what engine (or engine-series) you might have.
Tim
tclederman #366716 01/27/2008 11:22 PM
OK.... I can't see any numbers on the block, but the head has 388593 GM1 stamped on the top. The valve cover has 4 screws holding it down. (two on each side. Any ideas?
Dachshund #366746 01/27/2008 11:59 PM
The casting #'s are the raised #'s cast into the block. Try these two links. The info you seek should be there.
http://clubs.hemmings.com/clubsites/chevytalk/GMhistory/index2.html
http://www.mortec.com/location.htm
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
41Chevy #367129 01/28/2008 10:53 PM
Riding in the Passing Lane
The valve cover discription makes it a 235 1954 to 1962. Possibly a 261 also.
1972 Chevy c10 Cheyenne Super
