9 members (farmallb, JW51, Barney1951, klhansen, Bill Hanlon, Otto Skorzeny, 1955 1 Series, sron48, 1 invisible),
87
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,487 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Was sitting with my 261 idling at a light yesterday when suddenly there was a ticking followed by engine backfire--clatter, clatter, boom, clatter, boom, clatter, boom. I immediately pulled into a nearby parking lot and summoned my son with a car trailer. This morning I removed the valve cover to look for broken springs, lifters, etc.
The top of a push rod had broken and the piece was lying in the oil on top of the head.
Cause? Effect? | | | | | Joined: Nov 2003 Posts: 11 Junior Member | | Junior Member Joined: Nov 2003 Posts: 11 | rocker too tight? oil passage clogged in pushrod? | | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Cause????? Effect$$$$$$
Try a compressino test before you just fix what you can see | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | New set of push rods coming from Patrick's--didn't replace with new when engine was rebuilt. Dumb move. Will do compression test, etc. prior to saying all is well. Thanks for the response, guys. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Any chance they were too long putting too much strain on things?
40 Chevy 1/2 ton
| | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Nope. Were 11 1/4" long. Original to the 261 taken out of a running '59 Chevy grain truck prior to rebuild. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Did you put in a higher lift cam without replacing the valves/guides? Did you check the rocker arms for wear? New valve springs? It sounds like something hung up and broke the pushrod.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | You can run the compression check before the pushrods arrive and get a headstart on the other parts you'll need.
Be sure to open the throttle all the way while doing the test | | | | | Joined: Jun 2004 Posts: 19 Junior Member | | Junior Member Joined: Jun 2004 Posts: 19 | How many miles on engine? Recent rebuild? Have seen valve guides installed and not have proper clearance. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Jim, what good is a compression test if you can't open the valves?
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Sorry JB
Your right I been sick
I tend to interchange compression and leakdown test.....since I almost never use a compression tester | | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | Your probably right 4onthefloor, I went with a Howards cam and new guides but old intake valves you can see the results here in V8 Reason http://community.webshots.com/user/zeker6 what a sorry day that was. I think the unworn portion of the valves tightened in the new guides (Head done by a machine shop) because of the higher lift got a tap from the piston the rest is history, The darn intakes were the only thing not new in the valve train . Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
| | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | New stock 261 cam, rockers, valves, guides, springs, hardened seats, bored .60, head shaved .20, ported and polished. 8K miles on engine. See picture link on my post.
No problems since original set-up until now. Push rod appears to have suffered from metal fatigue prior to this problem. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, definately do a leakdown test, then you will know if you bent a valve when the pushrod broke.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Soooooooooo What did you findout????? | | |
