6 members (Steelonsteel, dt235sd, Mike Burns, Youngin' Tut 59, Hotrod Lincoln, Hanks custodian), 65 guests, and 2 robots.
Topics128,066
Posts1,055,871
Members48,428
#360 11/07/2004 5:39 PM
Was sitting with my 261 idling at a light yesterday when suddenly there was a ticking followed by engine backfire--clatter, clatter, boom, clatter, boom, clatter, boom. I immediately pulled into a nearby parking lot and summoned my son with a car trailer. This morning I removed the valve cover to look for broken springs, lifters, etc.
The top of a push rod had broken and the piece was lying in the oil on top of the head.
Cause? Effect?
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
#361 11/07/2004 5:55 PM
Junior Member
Junior Member
rocker too tight?
oil passage clogged in pushrod?
#362 11/07/2004 6:04 PM
Cause????? Effect$$$$$$
Try a compressino test before you just fix what you can see
#363 11/10/2004 3:13 AM
New set of push rods coming from Patrick's--didn't replace with new when engine was rebuilt. Dumb move. Will do compression test, etc. prior to saying all is well. Thanks for the response, guys.
1956 Chevy 3100
#364 11/10/2004 3:23 AM
Any chance they were too long putting too much strain on things?
40 Chevy 1/2 ton
#365 11/11/2004 2:46 AM
Nope. Were 11 1/4" long. Original to the 261 taken out of a running '59 Chevy grain truck prior to rebuild.
1956 Chevy 3100
#366 11/11/2004 6:52 PM
Did you put in a higher lift cam without replacing the valves/guides? Did you check the rocker arms for wear? New valve springs? It sounds like something hung up and broke the pushrod.
Paint & Body Shop moderator
#367 11/12/2004 12:34 AM
You can run the compression check before the pushrods arrive and get a headstart on the other parts you'll need.
Be sure to open the throttle all the way while doing the test
#368 11/12/2004 1:55 AM
Junior Member
Junior Member
How many miles on engine? Recent rebuild? Have seen valve guides installed and not have proper clearance.
#369 11/12/2004 7:42 PM
Jim, what good is a compression test if you can't open the valves?
#370 11/12/2004 7:58 PM
Sorry JB
Your right I been sick
I tend to interchange compression and leakdown test.....since I almost never use a compression tester
#371 11/12/2004 8:23 PM
Z
Z Offline
Your probably right 4onthefloor, I went with a Howards cam and new guides but old intake valves you can see the results here in V8 Reason
http://community.webshots.com/user/zeker6
what a sorry day that was. I think the unworn portion of the valves tightened in the new guides (Head done by a machine shop) because of the higher lift got a tap from the piston the rest is history, The darn intakes were the only thing not new in the valve train . Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
#372 11/13/2004 6:21 PM
New stock 261 cam, rockers, valves, guides, springs, hardened seats, bored .60, head shaved .20, ported and polished. 8K miles on engine. See picture link on my post.
No problems since original set-up until now. Push rod appears to have suffered from metal fatigue prior to this problem.
1956 Chevy 3100
#373 11/16/2004 12:40 AM
Yes, definately do a leakdown test, then you will know if you bent a valve when the pushrod broke.
#374 11/25/2004 2:59 AM
Soooooooooo What did you findout?????
