1 members (78buckshot), 112 guests, and 1 robot.
Topics128,136
Posts1,056,425
Members48,441
Apprentice
Apprentice
I just bought this '62 C20 and the inside of the doors look like they accommodate vinyl or fabric panels. I can't seem to find any info or aftermarket parts for these, any ideas?
Ex Hall Monitor
Ex Hall Monitor
Inside the trim panel were sheets of "waterproof" paper that were supposed to divert water away from the trim panel and into the bottom of the door where it could drain. These didn't have a very long life. I'm not aware of anyone who repops these. Eventually most manufacturers starting using plastic sheeting instead of paper. You can use any sheet plastic to make replacements. Just make sure the bottom is tucked into the slot so any water will be diverted into the bottom of the door.
Apprentice
Apprentice
I'm sure if we're talking about the same thing. The spot on the inside of the doors actually have a spot for some kind of panel. The door and window handles would go through the panels. I also think you could mount an armrest on it. Thanks for the help. I'll try to post some pics next time.
Ex Hall Monitor
Ex Hall Monitor
Always a good idea. Just be sure to post links to the pics instead of posting them directly into the thread.
Apprentice
Apprentice
Hey guys here's some pics of the door panel and a pic of a '62 owners manual. You can see there was a panel of some sort on the door with an armrest. Now, can I buy these panels aftermarket or do I have them mahttp://community.webshots.com/album/562316863hykXqgde special?n Thanks for all your imput.
Apprentice
Apprentice
Lets try that again, here's the link
'62 door panels
Moderated by  ndkid275, Phak1
