| | | Forums66 Topics128,012 Posts1,055,317 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | I have a 1947 Chevy 3/4 ton pickup (late series). I know that the original motor has been replaced with a newer one (from a 1965, I THINK). It has been sitting for about 10 years and we want to get it running again. It will either need a rebuild or a short block. Anyone know of a good place to find a rebuilt short block? Like I said, I THINK it is a 65 230 or 235 (have to check numbers to be sure). | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | I usewd to have the casting number link but now it don't work. try looking up moretech and search there for the casting numbers. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Post a description of the valve cover bolt pattern (and number of bolts that hold the valve cover down) and someone will be able to give a closer guess at what engine (or engine-series) you might have.
Tim | | | | | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | OK.... I can't see any numbers on the block, but the head has 388593 GM1 stamped on the top. The valve cover has 4 screws holding it down. (two on each side. Any ideas?
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The valve cover discription makes it a 235 1954 to 1962. Possibly a 261 also. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
