4 members (frogfarmer, Gdads51, latroca52, 1 invisible), 71 guests, and 3 robots.
Topics128,205
Posts1,057,425
Members48,471
Well I'm about ready to start my transmission , rear end swap in my 53 1/2 ton. {saginaw 4 speed, 64 chev 1/2 reae end} My question is does anybody know od a drive shaft that would fit in?After buying a patricks shifter and all tha other odds and ends, I'm looking to save a little money. If andbody has done this switch and found a drive line that fits, thaty would be great. Of course there's always the problem of finding that particular driveline, but you never know. thanks joethehuman
53 chevy 1/2 ton
[url=http://www.stovebolt.com/gallery/shannon_joe_1953.html]1953 Chevy 3100[/ur When life looks like easy street there is danger at your door
Any machine shop can re-do your drive line to fit the 53...lots cheaper than buying new.......
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
Hey Joe a friend of mine just had one shortened for way less than $100. The shop that did it is in Kingston, so if you don't mind a short ferry ride you should be able to get yours done cheap too.
You're looking for RustedNuts, another member here, and a Kingston WA resident.
check the yellow pages let your finger do the walking
1949 SUBURBAN
Thanks for the information. All I need now is a driveline to shorten. I suppose any 60 -66 1/2 ton would be a good candidate.Would it have to be a 1/2 ton?
