| | | Forums66 Topics128,196 Posts1,057,398 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 51 | Well I'm about ready to start my transmission , rear end swap in my 53 1/2 ton. {saginaw 4 speed, 64 chev 1/2 reae end} My question is does anybody know od a drive shaft that would fit in?After buying a patricks shifter and all tha other odds and ends, I'm looking to save a little money. If andbody has done this switch and found a drive line that fits, thaty would be great. Of course there's always the problem of finding that particular driveline, but you never know. thanks joethehuman ` 53 chevy 1/2 ton
[url=http://www.stovebolt.com/gallery/shannon_joe_1953.html]1953 Chevy 3100[/ur When life looks like easy street there is danger at your door
| | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Any machine shop can re-do your drive line to fit the 53...lots cheaper than buying new.......
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Hey Joe a friend of mine just had one shortened for way less than $100. The shop that did it is in Kingston, so if you don't mind a short ferry ride you should be able to get yours done cheap too.
You're looking for RustedNuts, another member here, and a Kingston WA resident.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | check the yellow pages let your finger do the walking | | | | | Joined: Sep 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 51 | Thanks for the information. All I need now is a driveline to shorten. I suppose any 60 -66 1/2 ton would be a good candidate.Would it have to be a 1/2 ton?
