6 members (Wickedbass, JW51, MRMEROTH11, GradyB, SWEET, 1 invisible), 63 guests, and 2 robots.
Topics128,066
Posts1,055,873
Members48,428
#366166 01/26/2008 7:26 PM
Apprentice
Apprentice
i was going to order some tune up parts but was thinking was our truck offered with the 235 as an option or has someone installed one later. the gentleman i bought it from did not mention anything and thought it was pretty much in original shape except it was blue now green
53 3800 "GRETCHEN" sold
http://good-times.webshots.com/album/561961050sRrxhL
70 Oldsmobile Delta 88 custom
75 gmc 3/4 ton 4x4
jdl Offline
Did a search on Google and apparently it was available. I know it was for the big 'Bolts but not sure for the 1-ton and smaller. Now, I thought that the 235 was supposed to be blue.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #366179 01/26/2008 8:14 PM
I believe the 235 was available in the larger 'bolts going back to the early '40s. The one in your truck looks to be a later engine, not the 235 "babbit pounder" that was original, but a full pressure 235, could even be a 261.
If memory serves correctly, the passenger car 235's were blue, the truck engines were gray.
Someone will surely come along and correct any misinformation I've given here.
waldo53 #366188 01/26/2008 8:38 PM
To know for sure, get the engine serial number from the pad behind the distributor. List it here and someone will probably decode it for you.
Steve
'49 3800
'52 3600
'57 3100
Here are some distinguishing characteristics of 1929-1962 Chevrolet engines. Casting numbers, serial numbers, and side/valve covers are quite helpful in identifying an engine.
Engine colors are discussed in this forum all the time. Here's an old article on 1912-1966 Chevrolet engine colors.
Tim
