2 members (WarEagle1, 1 invisible),
172
Mod | | | Forums66 Topics128,284 Posts1,058,522 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 11 Apprentice | | Apprentice Joined: Dec 2007 Posts: 11 | i was going to order some tune up parts but was thinking was our truck offered with the 235 as an option or has someone installed one later. the gentleman i bought it from did not mention anything and thought it was pretty much in original shape except it was blue now green | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Did a search on Google and apparently it was available. I know it was for the big 'Bolts but not sure for the 1-ton and smaller. Now, I thought that the 235 was supposed to be blue. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I believe the 235 was available in the larger 'bolts going back to the early '40s. The one in your truck looks to be a later engine, not the 235 "babbit pounder" that was original, but a full pressure 235, could even be a 261.
If memory serves correctly, the passenger car 235's were blue, the truck engines were gray.
Someone will surely come along and correct any misinformation I've given here. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | To know for sure, get the engine serial number from the pad behind the distributor. List it here and someone will probably decode it for you. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Here are some distinguishing characteristics of 1929-1962 Chevrolet engines. Casting numbers, serial numbers, and side/valve covers are quite helpful in identifying an engine. Engine colors are discussed in this forum all the time. Here's an old article on 1912-1966 Chevrolet engine colors.Tim | | |
