4 members (Peggy M, Jeff Ogden, cmayna, mk72), 46 guests, and 8 robots.
Topics128,012
Posts1,055,321
Members48,419
Page 2 of 2 1 2
50adrod #490006 01/05/2009 1:35 AM
been a while since I updated. all the sheet metal is temporarily hung. my new wheels are in. boyd smoothies 17x10 rear and 17x8 front. I also have the seats and am building the mounts for them.
with my torgue thrust wheels from my vette just for mock up
http://i11.photobucket.com/albums/a198/ahsum/crusin027.jpg
http://i11.photobucket.com/albums/a198/ahsum/crusin024.jpg
my new wheels
http://i11.photobucket.com/albums/a198/ahsum/boydrear.jpg
http://i11.photobucket.com/albums/a198/ahsum/boyddish.jpg
http://i11.photobucket.com/albums/a198/ahsum/boydfrontrear.jpg
new seats
http://i11.photobucket.com/albums/a198/ahsum/crusin030.jpg
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
50adrod,
I thought that it might be the same as earlier small blocks but I just wanted to float it by the experts here on Stovebolt.com to get some feedback and I hadn't seen anything speaking directly to this inquiry in the forum search.
1961 Chevy C10 Stepside
On my web site
Both engines are fine choices in my book. My 2 cents is "Don't get weak in the knees and bolt a carborator on these fine looking Hot Rod engines". I like the clean look of the LT1.
definitley no carb for me. mine will look like this except my engine covers will be painted to match the truck.
http://i11.photobucket.com/albums/a198/ahsum/vortec.jpg
I am almost complete with my LT1 4L60E swap. The Passenger side motor mount I replaced with one of a carb. 350. The only problem is you have to remove the Air Conditioning compressor to do this. I bought a bypass pulley to run the werp belt for about 40 bucks. There is not enough clearance for the Alt or power steering pump so I had to modify the passenger inner fender. I made a pocket in the drivers one to house the computer. If you are not quite as cheap as me you can buy a relocated computer harness to put it in the cab. My swap included a Camaro stub and I used the Trans crossmember out of a mid 70's 4x4 chevy pickup. A little trimming and a couple spacers and drill 4 holes and it works great inside the framerail.
CJ
1954 Chevy 1 Ton Panel
Dad.... I never knew there was something other than a Chevy to drive.....
Wow cj, sounds like your on the same path I took except for I used a vette motor.
Look thru my album, might look similar.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
Have you thought of the ATLAS 4.2 out of the trailblazer? Westers garage can re-flash the ECM and get you a bit more power besides turning it into a 5-wire installation (Ignition, Crank, Bat, Ground, fuel). Other than that, swapping a late model driveline is easy - get the complete donor vehicle and transfer everything. The gauge wires can be separated from the rest of the harness to slim it up a bit, or you can use the wires to feed the gauges.
Steve and the guys at Street and Performance re-programmed my Camaro 3.4 that I had in my RX7 about 10 years ago. Remember to purchase the VATS bypass as well unless you keep the VATS intact.
An odd but great combination would be the Caddy Northstar and a built up 4l60e from a 3.1 S-10 or 3.4 Camaro. Keep the Northstar from a 94-95 for OBD1 and there are a lot less wires and sensors
Yes very similar. Question: How does your LT1 cool with a downflow radiator, or did you switch it out to a crossflow? I have been eyeiny the DOwnflow listed on Ebay for a 54 chevy car and planning a little mod to a "Stock truck" LOL. I have looked at your page and admired the work. darn nice truck if I can say so!
CJ
I have no problems at all. I turn the fan off except in heavy traffic and it runs at 180 degrees all the time.
Originally Posted by CJO13
Question: How does your LT1 cool with a downflow radiator, or did you switch it out to a crossflow? CJ
Heat transfer doesnt really care if coolant flows vertically or horizontally. As long as the whole core is used
I should have added that I had the top hose fitting moved over to the left when the rad was made.
Thanks for the information. I will be ordering mine here shortly.
CJ
new wheels and tires on
http://i11.photobucket.com/albums/a198/ahsum/005.jpg
http://i11.photobucket.com/albums/a198/ahsum/crusin047.jpg
oak bed with stainless strips
http://i11.photobucket.com/albums/a198/ahsum/crusin042.jpg
the bottom half of the two tone will be dark cherry pearl the top half will be a very light gold
http://i11.photobucket.com/albums/a198/ahsum/001.jpg
custom door panels will be covered in leather and suede
http://i11.photobucket.com/albums/a198/ahsum/crusin038-1.jpg
engine is in for now, it is comming back out to be painted to match the truck and also do a mild cam install
http://i11.photobucket.com/albums/a198/ahsum/engine002.jpg
http://i11.photobucket.com/albums/a198/ahsum/engine005.jpg
steering column in and console is mocked up in cardboard
I dont like the woodgrain so I will paint the wheel truck color
http://i11.photobucket.com/albums/a198/ahsum/console005.jpg
http://i11.photobucket.com/albums/a198/ahsum/console007.jpg
Really nice work there. I love the smoothed out firewall.
You mocked up console gave me some ideas on how to mock up mine.
[b]I'm jealous![font:Comic Sans MS][/font][/b]
~Jim
50adrod,
I see from your build link that you are using a C5 pedal assembly. Did you need to modify mount to match firewall? The pedal with my motor is from an 06 Yukon which requires a more vertical firewall mount.
Great pictures
Originally Posted by lvillene
50adrod,
Great pictures
no it mounts directly to my firewall, I did repace my firewall with a recessed one so that may make a difference. I have one of those truck pedals also that thing was huge.
Page 2 of 2 1 2
