7 members (Chip O, 1955 1 Series, Gray_Ghost, JoergK., Peggy M, oldieoldie, 1 invisible),
177
Mod | | | Forums66 Topics128,191 Posts1,057,348 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 20 New Guy | | New Guy Joined: Jan 2008 Posts: 20 | Hey guys~ I am still trying to identify the brownie box in my truck 51 chevy 6500. Is there one of you out there that has a picture of a Spicer 6041 auxiliary transmission either in or out of a vehicle? If you can identify one from a picture there is a picture of my trans HERE. Thanx Jaysin | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If it has 4 gear positions it's a chance, the "4" in the model number is for four speed.
I'll check my books and get a length for you...
Grigg | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | OK, so far I can't find the length of the different models in my books, but have a few more to check...
Looking at the pictures in the manuals it probably is a Spicer 6xxx or a 7xxx. They have the same sort of mounting ears as seen on yours, and a 5831 is defiantly different. A 7xxx Spicer is really big, probably looks like it should not even fit, a 6xxx Spicer could look at home in your truck...
There really should be a tag on your transmission, and if not then you will find the two rivet or screw holes where it is missing. Try looking about 1 or 2" below the top on the side near a corner, start at the left front and then left rear.
Grigg | | |
