4 members (WICruiser, dwreills, 78buckshot, Shardean), 93 guests, and 3 robots.
Topics128,042
Posts1,055,516
Members48,424
#36592 05/25/2005 11:07 PM
Y
Junior Member
Junior Member
Y Offline
I would like to know the firing order for a 235 6 cylinder and also the engine code C284577? Also, Canadian VIN # 83104600042, what do these codes mean? Can anyone help me out?
#36593 05/26/2005 12:04 AM
Firing order is 1-5-3-6-2-4
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
#36594 05/26/2005 12:07 AM
Is that VIN on the door post? What vehicle is it in?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#36595 05/26/2005 12:18 AM
Y
Junior Member
Junior Member
Y Offline
Quote
Yes it's on the door, made in Canada stamp in a 1950 Chevy 3/4 ton pickup
#36596 05/26/2005 3:13 AM
8 3104 6 00042 should mean:
1958 [< if it was a TF series] model 3104 [½T pu] 6 cyl equipped, serial# 00042
unless they changed the year designation digit somehow before the 1955 2nd series
maybe the C on the engine number is for Canada? the rest of it is serial number, but should also say if it's solid or hydraulic lifters [truck or car]
don't quote me on that grin
#36597 05/26/2005 3:25 AM
Y
Junior Member
Junior Member
Y Offline
Thanks, that helps a lot.
#36598 05/26/2005 3:27 AM
Y
Junior Member
Junior Member
Y Offline
Quote
I tried that sequence and it still backfires, I wonder if I've got my #1 mark on my distributer cap wrong? Does the firing order go clockwise or counter?
#36599 05/26/2005 9:24 AM
if your plug wires are ccw your backwords i did the same thing and acturly got it running but they go cw on the cap
#36600 05/27/2005 3:33 AM
Clockwise is right. Usually the distributor is set so the rotor points toward the #1 plug for the #1 firing position. Should be about 2 o'clock.
Also, a trick to find the #1 in firing position is to hold a finger over the plug hole while turning the engine. When the pressure blows your finger off the hole you're close enough to locate the timing mark. Usually you can turn the engine by hand, using the fan blades.
Fred
52 3600
69 C-10
