8 members (NJC, cmayna, Hotrod Lincoln, lumbersawyer, JW51, 3B, cshades, 1 invisible), 100 guests, and 6 robots.
Topics128,064
Posts1,055,860
Members48,428
#365684 01/25/2008 6:10 PM
Hi all, Has anyone pulled the brk.backing plate off a 2ton rear end? My problem is not unbolting it, but how to get the oil slinger ring thats pressed on the axle off. Yes, I know a hammer would work but then I thought that after I had removed it putting it back on would be the problem, or should I say would it stay on beings that the factory pressed it on. I didn't see any mention of it in the shop manual. Has anyone seen mention of this in the overhaul manual,because that manual I do not have.
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
Riding in the Passing Lane
You should be able to pry it off & replace it when you put the backing plate back on. If it comes down to it you don,t have to have it on there but use it if you can. The seals we have now are better then back then. They quite putting them on in the 60s-70s.
1972 Chevy c10 Cheyenne Super
