4 members (59 fleet, mason86, Samantha, dt235sd), 29 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
#36502 11/24/2003 5:51 AM
I am installing a '55 Chevy 235 into my '53 truck and I was planning on using my '53 ditributor. What my problem is, is when I put the distributor into the engine it doesn't go in all the way. What I am wondering is will a '53 distributor work in a '55 engine or do I need to buy a new one?
#36503 11/24/2003 8:52 AM
did it drop down into the oil pump if it dont it will not go down all the way
#36504 11/24/2003 6:04 PM
Sometimes you have to turn the oil pump to align with the distributor shaft so the slot in the pump and the end of the shaft line up. Use a long screwdriver.
Fred
52 3600
69 C-10
