| | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36502 11/24/2003 5:51 AM | Joined: Jul 2003 Posts: 6 Member | | Member Joined: Jul 2003 Posts: 6 | I am installing a '55 Chevy 235 into my '53 truck and I was planning on using my '53 ditributor. What my problem is, is when I put the distributor into the engine it doesn't go in all the way. What I am wondering is will a '53 distributor work in a '55 engine or do I need to buy a new one? | | |
#36503 11/24/2003 8:52 AM | Joined: Oct 2003 Posts: 91 Member | | Member Joined: Oct 2003 Posts: 91 | did it drop down into the oil pump if it dont it will not go down all the way | | |
#36504 11/24/2003 6:04 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Sometimes you have to turn the oil pump to align with the distributor shaft so the slot in the pump and the end of the shaft line up. Use a long screwdriver.
Fred 52 3600 69 C-10
