6 members (3800GUY, BC59, Youngin' Tut 59, Gray_Ghost, dt235sd, 1 invisible), 126 guests, and 2 robots.
Topics128,140
Posts1,056,771
Members48,454
#364716 01/23/2008 6:29 PM
Apprentice
Apprentice
Well guys,
In the spirit of my proud determination to perform every single aspect of this build up by myself,with the exception of always welcome free advice of my elders, my body work continues on the driv. side of my cab.
This weekend was a real eye opener to how many hours can be spent satisfying your personal desire for perfection when it comes to lining up body lines, as well as making welds that dont require a "pack" of grinder wheels to look good!
Part 1 Continues:
HERES WHERE ALL THE WORK GOES DOWN:
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1581.jpg
THATS MY FRIENDS '57 IN THE FOREGROUND, MINES IN THE BACK LEFT.
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1580.jpg
THE TEMP. SAT. MORNING IN MY TAHOE!
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1570.jpg
WHEN I RECEIVED THE TRUCK, SOMEBODY HAD ALREADY PRETTY WELL MANGLED THE CAB CORNERS, SO THEY HAD TO GO.
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1512.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1513.jpg
SO I BEGAN WITH MAKING MY MARKS, AND CUTTING OUT THE OLD INNER AND OUTER CORNER.
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1519.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1517.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1516.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1520.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1522.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1533.jpg
THEN SIZED UP THE COMPETITION.
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1521.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1531.jpg
THIS NEEDED REMOVED TOO, NOT SURE WHAT IT IS, BUT I SAVE EVERYTHING.
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1523.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1528.jpg
THEN I STARTED WELDING IN THE NEW, STARTING WITH THE INNER.
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1560.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1561.jpg
WANTED TO PLUG WELD THIS BUT METAL DIRECTLY UNDERNEATH WASN’T COOPERATING.
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1559.jpg
THEN ONTO THE OUTER, STARTING WITH A CRIMP.
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1565.jpg
IT WAS SLOW GOING WITH ONLY THESE, AND A PAIR OF “MEAT CLAWS” BUT IT GOT THE JOB DONE.
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1562.jpg
THEN I BUSTED UP MY “MEAT CLAWS” A LITTLE WITH THE AIR GRINDER, AND THAT SLOWED THINGS DOWN EVEN MORE, GLAD I HAD GLOVES!
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1556.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1555.jpg
FOLLOWED BY WELDING IN THE OUTER, WHERE I PRACTICED WITH MY HEAT/WIRE SPEED FIRST ON “LIKE MATERIAL”, BUT STILL ENDED UP WITH A LOT OF GRINDING DUE TO BLOWING HOLES IN MY CAB!
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1576.jpg
IF YOU’RE A PROUD WELDER WITH A WEAK STOMACH, USE CAUTION WITH THE FOLLOWING PICTURES OF “WELDS GONE WRONG”! 
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1574.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1573.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1572.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1575.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1579.jpg
BUT, AFTER MANY HOURS OF DILIGENCE, PATIENCE AND GRINDER WHEELS, GAS AND ROD, IT CAME OUT TO MY SATISFACTION. NOTICE I ALSO WELDED UP MY STEP TO MY CAB CORNER.
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1566.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1567.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1577.jpg
http://i249.photobucket.com/albums/gg218/57Rat/IMG_1578.jpg
Theres nothing that can't be done. Say, if "they" can do it, so can I.
Hey 57 Rat,
That item in the back corner of the cab floor is where the jack was mounted.
Brian
Not bad,You might want to turn the heat up a smidge and drop the wire speed a hair and burn it a little longer.Got to watch out on those grinders i have seen and done some bad cuts with them. Don't you love the way the jap parts fit!
keep up the good work!
48GMC 5window,350,700R4,p/w,p/b,and a couple of homemade parts!
41 Sedan Delivery next up to be reborn!!
"Nothing is Junk,just unfinished projects" Desert rat with a spray gun!
Jap Parts???
I believe those are Chink Parts...
57Rat: I like your garage. Looks like a lot of room to work.
~Jim
Apprentice
Apprentice
Well, I wish i could take credit for the garage, but alas it belongs to my mentor and friend. He owns the 57 chevy in the foreground of the shop pic. I am mearly a very lucky sole who gets to stash his project in the corner and work on it on the weekends.
Very cool "Bodywork" he has done recentlt though. He welded in a '55 car dash into his '57 pickup cab. It looks really good with the double humps versus the single that came in the trucks.
Makes you wonder if all those Chink/Jap parts are recycled tuna cans or something?
Looks good!!!
Take a safety moment and chain those gas cylinders to that post!!!
Makes me squirm to see them that way.
R-Bo
1966 GMC 305V6 in the family
