7 members (Otto Skorzeny, Tom McGrath, Gdads51, TPR57C, 32Fordpuchoptop, Wickedbass, 1 invisible),
97
Mod | | | Forums66 Topics128,094 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | I'm trying to street rod a '57 chevy and want to relocate the gas tank from behind the seat. Are there other gas tanks that you might find in a salvage yard that might work? Or where can you get one where you don't have to pawn your wife's wedding ring? [email protected] | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | I did some work on a 57 truck a while back that had a 65 Mustang tank. It fits in between the rear frame rails. The bumber brackets have to come out to get it in. The filler is straight up through the bed wood. Fred
