8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL),
100
Mod | | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36474 01/22/2005 7:57 AM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | For those that don't remember or didn't read, I've been having random hard starting problems the last couple months. Not a slow starter just randomly cranks and no fire. Does it when warm and cold. Think I stumbled on something but, not sure what to do. Today, she fired right up for the drive to work. After sitting for a few hours I went out to start and she only cranked. I decided to see what would happen with a screwdriver on the starter. Turned the ignition on, screwdriver on starter and she fired right up. So, anyone know of probable causes or what might be going on? -David | | |
#36475 01/22/2005 11:58 AM | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | Maybe try cleaning all the wires on the starter. | | |
#36476 01/22/2005 3:56 PM | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | Mugsy, do you have the crank circut on the key? If so check the switch. The ignition circut could be failing in the crank position. I would also check all wires starting from the battery to the starter. Don't forget to check the grounds, they are as nessary as power. Mike | | |
#36477 01/22/2005 7:57 PM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Sloemoe, you mean starter engages as key is turned as opposed to older trucks with foot starter or a vehicle with a remote starter switch?
Just read your post again, sorry, I just woke up. Yep, it's key and ignition switch. I thought about changing ignition switch a month or two ago when I rolled up to a stop sign and lost all electrical and then motor petered out. 5 minutes later I had power and she started. It hasn't done that since but, I had a few of these hard starts before it happened and more frquently as of late. | | |
#36478 01/22/2005 10:29 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sometimes the hot wire on the back of the ign.switch gets burnt. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#36479 01/24/2005 12:13 AM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | OK, started digging into things yesterday and just finished up this morning. First thing I noticed was a couple bare wire spots on the purple ignition wire a few inches from the "S" terminal on starter. Wire was long enough to cut the bad part and splice new connector. Next I found the plug connector on firewall for ignition wire, temp. wire, etc. fairly corroded. Cleaned both sides of plug. Cleaned all connections, installed #2 gauge battery cables and installed new ignition switch. If I still get the hard starts, gonna have a look at the starter solenoid. And if still, the dizzy's comin' out and new one goin' in (it's still under warranty). -David | | |
