5 members (Southerntruck, RoadsScholar, 50Chevy3100, NorthCoast3800, Gray_Ghost), 118 guests, and 3 robots.
Topics128,100
Posts1,056,514
Members48,448
i searched but could not find the answer....
a po has removed the original turn signal guts in my 60 steering column. i have a signal stat 900 i'm going to mount in place. can i use the original 2 terminal flasher in the fuse panel? should i connect the pilot and load together on the single flasher wire or not use the pilot wire? thanks!
Riding in the Passing Lane
Howdy neighbor. You can use the 2 prong flasher if you have indicator lights in the dash. You can hook them to the front turn signals. If you want to use the pilot in the switch you will need a 3 prong flasher.
1972 Chevy c10 Cheyenne Super
thanks. the indicators are in the dash. so am i understanding correctly that the pilot is just simply to light the indicators on the turn signal stalk?
