| | | Forums66 Topics128,160 Posts1,056,902 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | What are people using as studs and nuts to connect the exhaust pipes to their Fenton headers?
I see The Stovebolt Engine Company sells a kit for it's headers, but I don't see anything like it for the Fenton headers?
Do I just go to my Flaps and see what they have in the DIY section?
Sorry if this is a bone head question. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's what I did. i also used a dab of hi temp (copper base) anti seize on the threads so they won't corrode together, in case disassembly is needed in the future.
Bill Burmeister | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I bought brass exhaust manifold nuts from our local NAPA dealer. They take a 9/16" socket and are about 3 times as tall as a standard nut. Easy on...easy off!
Dave | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Dave,
I've always used brass exhaust manifold nuts but I have never understood why they are preferred. Do they not seize as easily as steel nuts, or can they be broken off more easily than nuts (if they seize), or ???
Thanks, Tim | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, it's because they tend not to seize on the steel studs as badly. I actually don't remember what type of nuts I used, it's kind of hard for me to look. They might be brass. I know I used the anti seize on them anyway.
Bill Burmeister | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Steel studs with tall brass nuts, no need for anti-seize. NEVER have had a problem backing them off or getting a 1/4 turn just to be sure. The extra height gives you additional coarse internal threads so you can crank down on them without stripping. I've always used NAPA but I would venture a guess that any parts supplier could provide them.
Dave | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | My FLAPS has them in stock - in fact all of the parts store around here carry them. They are part of the "HELP" line of parts on display in most parts store I have been to - even the parts stores that you and I might not consider very good parts stores.  The studs in one of those packs, with the clear front and cardboard back, come in a couple of different lengths with a steel lock washer and "tall" brass nut. The points made above about the nut are good - no seizing and plenty of threads. Usually there are three in a pack, so for a set of headers you get two extra of everything. It's one of those genius marketing things, but they are the best I have found and I have used them for years on every set of headers I have ever installed - with no problems! I noticed recently that the studs now have a small hex heads on the ends of them so you can "wrench" them into the header. Bill, I think you'll be happy with these. Your truck looks like a good fit for them!!  And the brass adds some class!  Joe :crazy:
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | Great. Thanks everyone. I spent a little time looking online and didn't find anything. This was disappointing to me. I mean if I have to go down to the FLAPS, I will, but jeez I'm trying to be cool like my kids and do everything online. Heck, you guys are my only friends.  and I've only ever met one of you in person. See just like my kids "friends". | | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | Brass manifold nuts. They don't rust (like steel). Additionally, if they do sieze to the manifold stud, you end up tearing up the nut taking them off, not the stud. | | |
