| | | Forums66 Topics128,283 Posts1,058,504 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36295 01/12/2004 2:48 PM | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | Went hunting for a set of fresh plugs for the '61 235cid in the Apache. Old plugs were R45T AC Delco. All I could find quickly was a set of R45 Delcos. The R45's use a compression ring at the base and have 13/16" lug as opposed to the 5/8" that came out of there. The new ones fit fine, and I gapped them appropriatly. However they seem to be a little "shorter" in terms of what is exposed on the INSIDE of the head (in the combustion chamber). Am I looking for trouble with these plugs? | | |
#36296 01/12/2004 4:12 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Yachtcare,
The T indicates a tapered seat on the plug.
These were used in later V-8's (somewhere in the early '70's Chevy changed from the flat seat with the copper gasket to the tapered seat w/o gasket)
Sounds like the old plugs may have been incorrect for the 235. The R45's are the right ones.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
