| | | Forums66 Topics128,056 Posts1,055,796 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 6 New Guy | | New Guy Joined: Mar 2006 Posts: 6 | HELLO STOVEBOLT I HAVE A COUPLE QUESTIONS,I AM GOING TO HAVE A 1958=235 REBUILT.MY QUESTION IS WHEN YOU GET THE ENGINE REBUILT DO YOU HAVE TO BALANCE THE ASSEMBLY,WHAT DOSE THIS MEAN.ALSO MY SECOND QUESTION IS ON MY 216 THAT WAS IN MY 1949=3100 THE FRONT MOTOR MOUNTS HAS TWO HOLES IN FRONT ON THE ENGINETO BOLT THE ENGINE DOWN.THE 1958 DON'T HAVE ANY HOLES. CAN YOU TAKE THE FRONT MOTOR MOUNT PLATE OF THE 216 AND PUT IT ON THE 235 OR DO YOU HAVE TO DRILL HOLES IN THE 235 PLATE. THANK YOU FOR ANY INFORMATION PEPSI | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I don't mean to sound like an old woman, but please don't use all upper case letters in your post. It sounds like you're yelling and nearly impossible to read. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | pepsi, you will find answers to your two questions by using the search function. Also there is a good explanation of your intended switch in the tech tips. For the short answer, you should be able to drill holes in the lip of the front plate to fit the old motor mount. Balancing affects how the engine will feel and sound at higher RPM. | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Just drill holes in the plate,thats what I done when installing the 57 235 in my 37. | | |
