4 members (dt235sd, Rich'sToys, wilbur53, Stovebolt48), 173 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
#362102 01/18/2008 2:06 AM
tmm
Offline
I'm having no luck getting the rear brakes to work on a neighbors 55 GMC 350 series truck. I've bled the brakes numerous times but still no pedal. The master cylinder went out and I installed a new one but can't get the rear wheel cylinders to even move. But when I bleed them I get solid fluid. I plugged the rear line just before the rear wheel cylinders and have plenty of pedal. So I'm thinking the problem is in the rear. Any suggestions? Thanks,....
Either the rear brakes are way out of adjustment, or the wheel cylinders are seized
1970 C50 dump! saving orphans from the CRUSHER
3B Offline
Hy guys, I agree the rear brakes could be way out of adjustment, but if the wheel cylinders were siezed you'd have a good pedal but no brakes.
tmm,
Does your truck have a hydrovac unit? If so, did you bleed it as per the Maintenance Manual?
Tim
tmm
Offline
I'd already adjusted the brakes earlier. Now this truck does have the dual wheel cylinders so is there a special way to properly bleed them? This has really baffled me. Also, I'm thinking if the local Napa store sold me the wrong master cylinder. Is there a difference from the pickup MS and a 2 ton version?
Yes, a big size difference.
I would be surprised if you ever get the pickup one to work on that big truck, even with the brakes adjusted really tight...
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
tmm
Offline
It does have the hydrovac unit but I did not bleed it. My thought was if I plugged the line beyond the unit and just before the rear wheel cylinders and had great pedal that the hydrovac wouldn't be the problem. Is that wrong for me to assume that? What is the proper way of bleeding the hydrovac?
Do you have a shop manual for the truck?
Grigg
tmm
Offline
[quote=Grigg]Do you have a shop manual for the truck?
No I do not but I'm still searching,..
Then you should look here
http://chevy.tocmp.com/
And here for a 54 manual
http://chevy.tocmp.com/shop/1954truck/index.html
Follow the instructions for the brakes, it may be helpful?
Did you figure out if you have the right bore MC?
Grigg
---All pictures---
If the truck has the dual wheel cylinders with the shoes top and bottom, there is a special procedure for bleeding them. That is because the cylinders are vertical and the air doesn't get to the bleeder with the brakes adjusted normally. Read the procedure in the manual.
1951 1 Ton Completed
