7 members (55shaker, dt235sd, Hanks custodian, NJC, 3B, Gdads51, 1 invisible), 211 guests, and 2 robots.
Topics128,086
Posts1,056,098
Members48,434
#36202 08/07/2004 7:30 AM
Hi Guys,
My brother called me today. Seems his 49 Chevy has seen better days. The old powerplant has bit the dust. I was wondering if there are any 6's from late model autos that will just bolt right in?
kskt4
Junior Member
Junior Member
Hey there,
You are up late, but then so am I. The only bolt in 6 will be the 235 until 1962. In 1963 Chevy went to the 230/250 series motors.(different bellhousing pattern) Some later 235's even had the front motor mount plate, although the mounting holes weren't drilled (like the 235 I got out of a 1960 Chevy wagon). The 235's are cheap & easy to find. Other motors require welding in custom motor mounts or whole new subframe. I would go with a 235. Good luck.
Scooter
I am a total control freak. I shift for myself. No auto's!
1948 1 ton 5 window w/235
1951 1.5 ton dump w/235
1966 3/4 fleetside w/283
1962 Bel Air 235 w/OD
& one rusty,beat up,240K mile '82 Chevy 3/4 ton
Thanks 62belair,
I will phone a few of the local auto wreckers and see what they have.
kskt4
Anonymous
Unregistered
Anonymous
Unregistered
Being that you are in Canada - you might also look at some of the pre 63 Pontiacs as they were sometimes fitted with 261 motors that are as close to a bolt in as a 235 - also GMCs were motivated by 235s from the mid 50's on up in Canada.
Thanks Ken,
I will look into that option also.
kskt4
