1 members (klhansen),
161
Mod | | | Forums66 Topics128,089 Posts1,056,140 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36202 08/07/2004 7:30 AM | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Hi Guys, My brother called me today. Seems his 49 Chevy has seen better days. The old powerplant has bit the dust. I was wondering if there are any 6's from late model autos that will just bolt right in?
kskt4 | | |
#36203 08/07/2004 8:50 AM | Joined: Mar 2003 Posts: 23 Junior Member | | Junior Member Joined: Mar 2003 Posts: 23 | Hey there, You are up late, but then so am I. The only bolt in 6 will be the 235 until 1962. In 1963 Chevy went to the 230/250 series motors.(different bellhousing pattern) Some later 235's even had the front motor mount plate, although the mounting holes weren't drilled (like the 235 I got out of a 1960 Chevy wagon). The 235's are cheap & easy to find. Other motors require welding in custom motor mounts or whole new subframe. I would go with a 235. Good luck.
Scooter
I am a total control freak. I shift for myself. No auto's!
1948 1 ton 5 window w/235 1951 1.5 ton dump w/235 1966 3/4 fleetside w/283 1962 Bel Air 235 w/OD & one rusty,beat up,240K mile '82 Chevy 3/4 ton
#36204 08/07/2004 2:34 PM | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Thanks 62belair, I will phone a few of the local auto wreckers and see what they have.
kskt4 | | |
#36205 08/07/2004 4:39 PM | | Anonymous Unregistered | | Anonymous Unregistered | Being that you are in Canada - you might also look at some of the pre 63 Pontiacs as they were sometimes fitted with 261 motors that are as close to a bolt in as a 235 - also GMCs were motivated by 235s from the mid 50's on up in Canada. | | |
#36206 08/11/2004 5:50 AM | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Thanks Ken, I will look into that option also.
kskt4 | | |
