2 members (BC59, Uncles51), 103 guests, and 1 robot.
Topics128,041
Posts1,055,481
Members48,424
#361726 01/17/2008 4:32 AM
I know this isnt an electrical question but since the speedo is in the dash I thought this would be a good place to start.
I had disassembled my speedo to clean and lube the internal parts and during the process I broke the shaft that the speedo needle mounts to. My truck is a 53 GMC long bed with a 90mph dial. Will a shaft from a 80mph speedo work be as accurate as the 90mph shaft?
thank you in advance (design)
Pletch
65 Chevy fleetside
69 Datsun Roadster (sold)
68 Chevy long bed step side (sold)
53 GMC 3100 (sold)
Pletch #361812 01/17/2008 8:15 AM
Try using a wd40 straw to reattach the broken shaft together...
if there is enough shaft to do it....
GMC: Get More Cash...
1958 GMC
My Webshots photos
If you compare the 80 to the 90 mph speedo you'll notice that the range of numbers covers the same space on the speedo face. This would lead me to assume that the internal gearing is different.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
