| | | Forums66 Topics128,018 Posts1,055,339 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36175 01/17/2002 9:00 PM | Joined: Dec 2001 Posts: 14 Member | | Member Joined: Dec 2001 Posts: 14 | I am getting ready to put the 3 speed tranny back on my 54' Chevy. It has an enclosed torque type driveline, what do I need to lube and where? Does the driveline need to be packed with grease? What about the u joint ball housing? little help!
rje
#36176 01/18/2002 6:19 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I use 90-140 weight in my tranny. It says in shop manual to remove square headed pipe plug and lubricatethe universal joint bearings through the opening and replace plug. Fill transmission with 1 1/2 pints of fluid. I can't find where they actually say to fill main tranny body in book, I assume it has a plug somewhere on side to fill it. It just says to fill to just below plug hole. Usually you stick your finger in hole and you can feel oil.  | | |
