| | | Forums66 Topics128,043 Posts1,055,605 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36169 02/21/2002 3:38 AM | Joined: Jun 2001 Posts: 34 Member | | Member Joined: Jun 2001 Posts: 34 | HELP PLEASE. Can someone advise me as to how to remove the tailshaft from a 89 Camero T5? I can seperate the gearbox and tail about 3/4 inch but that is all. What am I missing? Is there a pin or some hidden bolt? | | |
#36170 02/21/2002 5:09 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You must not have removed the pin that holdes the shift selector on the shift shaft. You do not actually remove it but drive it down out of the shafts way, once apart it is removed completly to be put back in from the top on assembly.
See the USA in your vintage Chevrolet! My Blog | | |
