12 members (Joe H, Gray_Ghost, Woodcmiami, fonz8261, 2-Ton, cmayna, 55shaker, kades51, Forty9, NorthCoast3800, Robert Crandall, 1 invisible),
103
Mod | | | Forums66 Topics128,169 Posts1,057,037 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 141 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 141 | Hello, As I am getting ready to pull my cab, I have been advised to replace my wiring harness..which sounds like a great idea. Can anyone recommend a cost friendly solution or source? So far the best price I found is with American Classic truck parts at 195.00. I have an alternator not a generator. I do have a harrison Deluxe heater that I believe was installed at the factory, I am not sure if the harness kits include these pieces.
Thanks, brian | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, if the existing wiring isn't 100% good looking, it's best to replace with new - that's about the price they all have, and what I've paid - there will be 2 listed, one for "w/ generator", one "w/ alternator" ... the heater just uses an 'accessories' power source wire from the ign switch also if the truck doesn't have a fuse panel, just above the pedals [they usually only added that if it was ordered with a number of acessories], it's worth getting one, which usually include some accessory wires Bill | | | | | Joined: Oct 2007 Posts: 141 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 141 | Hello, I am looking at: EZ wire Hot Rod Wire and the American Classic Parts Harness.
If I have a 58 that has an alternator, a cab light, and a heater how many circuits should I be looking for.
would a 12 circuit harness do the trick? Do you typically need to purchase an additional harness for the heater? Has anyone used the shrink tubing?
Thanks, brian | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Brian, I will have to wire my 4t6 sooner or later and have considered Rebel Wire . They have a 8 circuit kit for $120 and a 10% for Stovebolt contributors. Never used them but another option I'm considering. Good luck. Dan | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | my opinion is the factory style repro harness that is tape wrapped is much preferable to the rod style harnesses that have exposed wires that are zip-tied, and the extra runs included aren't needed if you're not planning on things like electric rad fan or AC, electric windows, etc ... a number of folks here like the rod style ones tho
no extras required with the standard harnesses available, including shrink tubing, although where you custom fit length [mostly rear, left long for long beds, cut for short beds] it is a nice touch, easy to use
Bil | | |
