| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36150 08/08/2002 7:12 PM | Joined: Apr 2002 Posts: 15 Member | | Member Joined: Apr 2002 Posts: 15 | Need a quick advise on something...
My wife had some OLD tires mounted up quickly to get an old truck she purchased home. They mounted radials on the back, and biased on the front. Sames sizes (basically)...
Commments?
I can't remember the rule on mixing. I think she should be OK, but she has a 75 mile drive to do tonight...just wanted to run this past....
Quick comments VERY appreiated!
Jim | | |
#36151 08/08/2002 7:18 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 |
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#36152 08/08/2002 7:20 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The old rule is radials on the back, just like you got em.
Fred 52 3600 69 C-10
#36153 08/08/2002 7:21 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Take it easy and should be no problem.You will have problems if it is the other way around.Is she taking a spare?
#36154 08/08/2002 7:50 PM | Joined: Apr 2002 Posts: 15 Member | | Member Joined: Apr 2002 Posts: 15 | That's what I thought...Radials on the back...Yess to the spare! Just wanted to make sure...Don't want to damage the truck...or the wife...don't tell her I said that...
Thanks EVERYONE!
Jim | | |
#36155 08/09/2002 2:29 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | OK!! Since no one else asked- What is the "Old Truck"??? I do hope you have her trained right and it is a Stovebolt-LOL.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#36156 08/22/2002 2:47 AM | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | And why do the radials go on the back? What difference does it make?
"Happiness equals reality minus expectations" - Tom Magliozzi
#36157 08/22/2002 4:08 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I was told that you don't want quick handling radials up front which bias ply tires on the back can't follow so well. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#36158 08/22/2002 6:59 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Problem with radials on the front and bias on the back is with braking. The radials have far more traction, and if your brakes aren't properly adjusted you can swap ends in a hard stop.
