3 members (Hotrod Lincoln, 2-Ton, 1 invisible),
63
Mod | | | Forums66 Topics128,021 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Does anyone have a number for the replacement filter for my glass bowl fuel filter. I'd like to get one at my FLAPS but the filter I have doesn't have any numbers on it. It's an AC filter, if that helps. Also how often do you have to change these things? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Purolator L30034 fit the one on my 57 235, changed when there was evidence of major sediment, rarely
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And what year would that be, I'm guessing a '46??? Is it for the fuel pump or the inline filter?? Ya might try looking at an AC Delco GF-124. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | If your FLAPS does FRAM, a CG3 will fit as well, but only the paper ones... the funky felt looking ones don't fit in the bowl. | | |
