3 members (Hotrod Lincoln, BC59, 1 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 39 Apprentice | | Apprentice Joined: Oct 2007 Posts: 39 | Does any know if there are patch panels made for the rear bottom of the front fenders on a 1948 1 TON AD truck? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Good question. I would think up north with all the road salt those parts would need patching. Chevy Duty doesn't carry them in their catalog. You might call to verify. You may have to make your own.
~Jim
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I don't believe there are any front fender patches made for the AD trucks
Bill | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | I don't think patch panels are available. If you are lucky, maybe you can find better fenders to replace yours. Otherwise you have to pay dearly for new ones or repair the old ones. That is what I did for a friend on his '54 3100. It is a lot of work but it can be done. | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | I think Wheelwright Restorations makes them. He also has ads every now & then here on the bolt & on ebay...Joe | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Maybe you could find a crunched fender cheap and cut patches from it. Check with Jimbo in the For Sale forum. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Wheelwright does custom work so he could fab it for you. Might be costly but a new fender will be near $400. You might also think about fiberglass repair.
~Jim
