1 members (dt235sd),
60
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#3606 04/09/2005 12:27 PM | Joined: Dec 2004 Posts: 20 New Guy | | New Guy Joined: Dec 2004 Posts: 20 | All, I just bought a 235 from a '59 pickup to put in my '51 3800. Being a later 235 it has side engine mounts in the front. I've read the standard instructions regarding changing the mounts from my existing engine to this one but was wondering if anyone has any experience is keeping the side engine mounts. Can this be done? Thanks | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | The 59 has the side mounts,but they were not used in the truck. The truck was mounted at the front of the engine and at the bellhousing.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Dec 2004 Posts: 20 New Guy | | New Guy Joined: Dec 2004 Posts: 20 | Tommy, Yep, my current engine is mounted in front but I was looking to see if anyone had made use of the side mounts of the later engine. For example, it seems brackets could be fabricated easily enough but I was hoping to hear from someone who has done it. PAFarmer | | |
#3609 04/09/2005 10:07 PM | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | PaFarmer, why don't you just drill 2 holes in the bottom flange of the front cover, and mount it like the 216? That's what I did. I put a 1957 235 in my 1949 3/4 ton Chevy truck. Worked great. KT ------------------- 1949 3/4 ton Chevy
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
#3610 04/11/2005 12:18 AM | Joined: Dec 2004 Posts: 20 New Guy | | New Guy Joined: Dec 2004 Posts: 20 | KT, Thanks for the tip, looks like that will work for me too. PAFarmer | | |
