| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | The fuel gauge in my truck (1970 C10) recently stopped working. When I first noticed a problem, the gauge would fluctuate from empty to full or anywhere in between. This was with the truck parked in the yard with the engine running. I was having a problem with trash from the old fuel tank clogging up the fuel filter and gunking up the carb so I decided to buy a new tank and sending unit. I figured the new sending unit would solve the fuel gauge problem but it hasn't. Now the gauge doesn't move off of the empty mark.
What do I need to do to get the gauge to work again? | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | If memory serves the wire that provides power may have a loose connection somewhere. I would look there.
58' 3200 235 3-speed/OD
| | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Thanks Apache, maybe I will have some free time after work tomorrow to check it out. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Ralph, Here's a tip that may help. Haven't made it that far yet! Dan | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Got the fuel gauge to work today. Must have been a bad connection at the sending unit. I disconnected the wire then connected it again and the gauge works but it isn't correct. The tank is at least 1/2 full and the gauge shows 1/4.
Is there a way to calibrate the sending unit? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | when you have a full tank bend the arm to read full, when it reads empty, pay attention to how much you put in and you'll know what "empty" means
Bill | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | | | |
