8 members (Nick in Manitou, tclederman, papas52, Robert Crandall, MikeStone1953, Gray_Ghost, Grizzly 34s, 66flea),
65
Mod | | | Forums66 Topics128,159 Posts1,056,901 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 198 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 198 | Here's the question:
My '55 1st edition has a 261 (in place of the factory 235)coupled to a factory original Hydra-Matic 4-speed with fluid coupling versus torque converter. I am spelling this out so that no one thinks I am discussing a "modern" Hydramatic!
In 1956, the smallblock v-8 was available on the task force trucks, AND could be ordered with a "Hydra-matic". I was not positive that this was the "original" iron case Hydra-Matic like I have, so I checked the gear ratios in the 1956 shop manual. They are identical to mine, so I am THINKING this WAS indeed the original iron case HydraMatic and not one of the "new" automatics introduced around 1956.
IF this is true, shouldn't I be able to couple any smallbloack CHevy V8 to my Hydra-Matic? Or, did the early smallblocks have any wierd bellhousings or adaptors fore the automatic?
Jim G | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | if it,s bolted to a 235 or 261 it willnot bolt to a V8...doc | | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | The 6 cyl. hydra-matic actually has sort of an adapter plate between engine and trans. I know that there were some hydramatics in Oldlmobile, Pontiac, Rolls Royce, Cadillac, and others. I don't have any idea if a bellhousing is available for a modern smallblock bolt pattern. The other problem might be a flywheel that is actually front part of torrus housing as well as a starter. If you decide to do away with the trans for something more modern, I may be interested in picking up a spare hydramatic if it is for a torque tube driveshaft. Actually even the 261 if same circumstances you decide you need a more modern driveline.
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | If you can find the correct v8 hydro parts, it will work. I tried some time back to find a v8 hydro bell housing, but could not find one. You might try looking for one on the HAMB BB. | | | | | Joined: Dec 2007 Posts: 198 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 198 | Greg H: My AD truck is a 55 1st edition, so it has the open Hotchkiss type drive from the factory.
Lonnie: So I am correct - the parts exist, but might be rare huh?
Jim G | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy JimGnitecki, I had a 57 Chev 1 ton p.u. with a V8 hydramatic dual range four speed transmission, You will need a V8 bellhousing, flywheel, possibly a torus cover, and possibly the the two fluid coupling elements, and a V8 hydramatic starter [ whose solenoid hangs almost upside down when installed] hope that helps. | | | | | Joined: Dec 2007 Posts: 198 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 198 | Hy JimGnitecki, I had a 57 Chev 1 ton p.u. with a V8 hydramatic dual range four speed transmission, You will need a V8 bellhousing, flywheel, possibly a torus cover, and possibly the the two fluid coupling elements, and a V8 hydramatic starter [ whose solenoid hangs almost upside down when installed] hope that helps. Wow, that helps! Thank-you, 3B.  Jim G | | |
