7 members (klhansen, edgardo, Hanks custodian, TexasJim50, stlcardinalsguy, Woodcmiami, 1 invisible),
57
Mod | | | Forums66 Topics128,059 Posts1,055,820 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Just got my 3" dropped axle from Sid installed. I'm totally stoked as to how this truck rides, steers, and handles. I've had 2 MII front ends and I think this is as good or better than either one of them, and at about 1/3 the cost. Seriously. I've captioned the photos on this link, hopefully it will be helpful to someone: http://community.webshots.com/album/562048090uoVuBn | | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | Lookin good!!!! Glad to hear how well it handles etc. I'm still thinkin that I don't need ps. Thanks for sharing! | | | | | Joined: Jan 2004 Posts: 22 Apprentice | | Apprentice Joined: Jan 2004 Posts: 22 | Waldo, How come the drag link had to be modified/shortened
JJ and 4
Later JJ and 4 Keep the shiney side up
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | JJ and 4; Ordinarily it wouldn't but I moved my steering box forward to give me a little more room in the cab. | | | | | Joined: Jan 2004 Posts: 22 Apprentice | | Apprentice Joined: Jan 2004 Posts: 22 |
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Nice work. Like the ride height! | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Looks good...just to be clear, did you do a mono springs and dropped axel? I just had Sid quote me a 3" for my 55 3/4 ton yesterday.
Keith | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Keith, I was running monos with the stock axle before the swap but I didn't like the harsh ride and short spring travel. With the dropped axle I went back to my stock springs (minus 3 leafs). The ride is nice and soft with plenty of spring travel and no bottoming. I forgot to mention in the photo shoot that I'm using a pair stock application gas shocks from Kragen's.
I'm keeping the mono's in case I want to experiment with an even lower ride height. | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | thanks for the clarification Waldo. It's what I'm doing on my second series and I'm glad you're happy with it.
Keith | | | | | Joined: Nov 2007 Posts: 55 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 55 | Waldo, have you tried flipping the top spring over to get a "reversed eye"? That should get you another easy inch of drop for free.
Dave | | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Dave, honestly I never thought of that. Sounds like it should work. I may just give that a try. | | | | | Joined: Apr 2006 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 87 | would that work? surely fitted upside down it would just push the spring the wrong way? i.e no spring? | | | | | | Dave Giorgi Unregistered | | Dave Giorgi Unregistered | RUSTHATER,
I was thinking that also , so I am glad you asked. Dave have any photos of that?
Dave | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Reversing the eye is an old school way to lower a leaf spring car or truck. The way I've seen it done is to reverse the arch on the spring using a press and spendng a couple hours reversing the arch a little at a time.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Could a spring shop de-arch a main leaf so it could be flipped upside down? Thus ending up with the reversed eye main leaf? | | | | | Joined: Nov 2007 Posts: 55 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 55 | Could a spring shop de-arch a main leaf so it could be flipped upside down? Thus ending up with the reversed eye main leaf? Absolutely. It's old school, people have been doing it for years. Check the H.A.M.B. website for a pictorial lesson on how you can do it yourself. Dave | | | | | Joined: Nov 2007 Posts: 55 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 55 | | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | or get a reversed eye main from the spring shop... probably less labor and safer. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Dave - thanks for that link to H.A.M.B., looks like that should work.
What about shortened shackles? Someone mentioned that somewhere. Can you just redrill your stock shackle plates, and how low can you go before problems develop??? | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Out of curiosity are you running 15" or 16" wheels? Could the same effect be used with either? Thanks | | | | | Joined: Nov 2007 Posts: 55 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 55 | Dave - thanks for that link to H.A.M.B., looks like that should work.
What about shortened shackles? Someone mentioned that somewhere. Can you just redrill your stock shackle plates, and how low can you go before problems develop??? An easy way to get shortened shackles on the rear is to just replace them with a pair from the front. You could redrill them also, shortening them up to the point of interference to the bolt that holds them together. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Can you just redrill your stock shackle plates, and how low can you go before problems develop??? The holes in the shackle plates are tapered and therfore not as easy to re drill as one might think.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Nov 2007 Posts: 55 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 55 | Why would they be tapered? | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | The threaded pins are tapered on the ends. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Yes, they are tapered. They only go on one way. Ya' know, shortened shackles would be a good aftermarket product for some enterprising machinist to make and sell. | | | | | | Dave Giorgi Unregistered | | Dave Giorgi Unregistered | Davealden,
First off welcome to the site and secondly thanks for the information.
Dave | | | | | Joined: Nov 2007 Posts: 55 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 55 | The threaded pins are tapered on the ends. You're right....I just looked at some NIB shackles tonite...they are indeed tapered. I learn something new everyday. Hopefully. Dave | | | | | Joined: Nov 2007 Posts: 55 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 55 | Davealden,
Dave Thanks, Dave! | | | | | Joined: Nov 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 96 | Nice truck.Good color,stance and oh yeah, the hubcaps. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | are you running the stock steering box? | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Was just curious...what is the new ride height with the stock springs minus 3 leafs....say from the bottom of the front bumper to the pavement and what is your tire/rim size? Thanks in advance.
Dave | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Yes, stock steering box but relocated per the pictures.
Wheels are 6-lug 15". Tires are P215/75R-15
Pavement to bottom of bumper is 8 1/4" Pavement to front fender well opening is 25"
I can easily go another 2" lower in front by putting my de-arched mono-leafs back on but am happy with the ride and the look for now.
| | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | I haven't tried that mainly because I haven't got the dropped axle yet- I have a 3/4 ton and an extra 1/2 ton axle. Sid had 1/2 tons but no 3/4 tons-He gave me a king pin to king pin measurement. It was 1-1/2" shorter than what I have. Possibly it shunk when he dropped it don't know but I'm up in the air. May send him mine to be sure. The subject comes up here often..an there are varying opinions but many swear the axles(1/2 and 3/4) are the same.
Thanks for tyhe info-
Keith | | |
