3 members (Wayne67vert, porsche, delky), 104 guests, and 2 robots.
Topics128,060
Posts1,055,839
Members48,427
#360446 01/14/2008 3:12 AM
The fuel gauge in my truck (1970 C10) recently stopped working. When I first noticed a problem, the gauge would fluctuate from empty to full or anywhere in between. This was with the truck parked in the yard with the engine running. I was having a problem with trash from the old fuel tank clogging up the fuel filter and gunking up the carb so I decided to buy a new tank and sending unit. I figured the new sending unit would solve the fuel gauge problem but it hasn't. Now the gauge doesn't move off of the empty mark.
What do I need to do to get the gauge to work again?
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
If memory serves the wire that provides power may have a loose connection somewhere. I would look there.
58' 3200 235 3-speed/OD
Thanks Apache, maybe I will have some free time after work tomorrow to check it out.
Ralph Davis
Ralph,
Here's a tip that may help. Haven't made it that far yet!
Dan
Got the fuel gauge to work today. Must have been a bad connection at the sending unit. I disconnected the wire then connected it again and the gauge works but it isn't correct. The tank is at least 1/2 full and the gauge shows 1/4.
Is there a way to calibrate the sending unit?
Ralph Davis
when you have a full tank bend the arm to read full, when it reads empty, pay attention to how much you put in and you'll know what "empty" means
Thanks, Bill.
Ralph Davis
