| | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 7 New Guy | | New Guy Joined: Dec 2007 Posts: 7 | Hi Folks,
I'm assembling an old 283 for a friend, I'm at the point of installing the rear main seal and wondered if there is a trick to putting it in without damaging the seal. The package with the seal included a 'shoehorn' to use during installation, but I'm not sure how to use it.
Any suggestions would be appreciated.
Thanks Mike | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | The shoehorn goes behind the seal so as not to peel the back, inner, edge of the seal off against the sharp block.I have made them with a piece of banding strap crimped into a short piece of cooper or steel tube. Stager the ends at 2 o'clock and 8 o'clock so as not to get a leak. Make sure your #5 bearing clearance is no more then .002, because even a new seal can't control a lot of oil slash.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Dec 2007 Posts: 7 New Guy | | New Guy Joined: Dec 2007 Posts: 7 | Thanks Shop Shark, much appreciated. I got it now. | | |
