8 members (Hotrod Lincoln, tclederman, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom, Otto Skorzeny), 182 guests, and 1 robot.
Topics128,089
Posts1,055,988
Members48,430
#360271 01/13/2008 6:38 PM
Hi Folks,
I'm assembling an old 283 for a friend, I'm at the point of installing the rear main seal and wondered if there is a trick to putting it in without damaging the seal. The package with the seal included a 'shoehorn' to use during installation, but I'm not sure how to use it.
Any suggestions would be appreciated.
Mike
The shoehorn goes behind the seal so as not to peel the back, inner, edge of the seal off against the sharp block.I have made them with a piece of banding strap crimped into a short piece of cooper or steel tube. Stager the ends at 2 o'clock and 8 o'clock so as not to get a leak. Make sure your #5 bearing clearance is no more then .002, because even a new seal can't control a lot of oil slash.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Thanks Shop Shark, much appreciated. I got it now.
