7 members (hdgeren, NJC, Wickedbass, Gone, Otto Skorzeny, rfs56trk, Peggy M), 53 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#36016 10/14/2004 1:29 PM
Is a 4spd out of a 50's 1/2 ton the same as my 4spd in my 1950 3/4 ton?
#36017 10/14/2004 2:02 PM
It should be. I've seen the same tranny in the 1/2 ton to the 2 1/2 ton. If it is a 216 or 235, odds are it is the same 4 speed.
#36018 10/14/2004 6:18 PM
Anonymous
Unregistered
Anonymous
Unregistered
Rear output section may be a little different. Weren't the 1/2 tons enclosed driveline while the 3/4 tons were open driveline during these years? In any case the tranny should be the SM 420.
#36019 10/14/2004 7:05 PM
The 1/2 ton are enclosed driveline. However, the 3/4 ton are also enclosed but only half way back. From there to the differential, it is open.
Thanks for the help
