| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36016 10/14/2004 1:29 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | Is a 4spd out of a 50's 1/2 ton the same as my 4spd in my 1950 3/4 ton? | | |
#36017 10/14/2004 2:02 PM | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | It should be. I've seen the same tranny in the 1/2 ton to the 2 1/2 ton. If it is a 216 or 235, odds are it is the same 4 speed. | | |
#36018 10/14/2004 6:18 PM | | Anonymous Unregistered | | Anonymous Unregistered | Rear output section may be a little different. Weren't the 1/2 tons enclosed driveline while the 3/4 tons were open driveline during these years? In any case the tranny should be the SM 420. | | |
#36019 10/14/2004 7:05 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | The 1/2 ton are enclosed driveline. However, the 3/4 ton are also enclosed but only half way back. From there to the differential, it is open.
Thanks for the help | | |
