5 members (WICruiser, GMCJammer51, Southerntruck, Phak1, NorCal52Suburban), 73 guests, and 1 robot.
Topics128,196
Posts1,057,395
Members48,471
JC
Offline
Hi All,
I have been reading Chilton Repair Manual in my spare time and have a question that has always bugged me:
What is the definition of a "turn" in degrees?
Is one full turn 360 degrees or 180? Half a turn 180 degrees or 90? A quarter turn 90 degrees or 45?
For instance, in setting the idle speed on a Rochester BV carb, "Turn the idle screw slightly to seat, and then back out 1 1/2 turns" ... "adjust the mixture screw to obtain a 20 rpm drop, then back out screw 1/4 turn". On hydraulic valves, "when all play has been removed, turn the adjusting nut in 1 full turn"
When I turn a screwdriver, wrench or ratchet I consider one physical turn equal to 180 degrees. Am I totally offbase on this? Any input? Am I thinking too hard on this subject? Thanks!
JC in KC
"The future will be better tomorrow." Dan Quayle
1965 Chevy C10 Long Fleetside
1 full turn would be 360 degrees.
Bill Burmeister
Think of that screw having a mark on one side. Turn it 180 degrees and the mark will now be on the opposite side of where it started. So, in order to get a full turn, 360 degrees, you have to start from where the mark is and bring it around fully to end where it began. One full turn.
jdl Offline
This is math. 180 is a line. Think of 360 as a full circle.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
JC
Offline
Thanks for all the input. I've done a lot of math in my time and also a lot of survey work dealing with degrees, radians, azimuths etc., but never seen any reference to a "turn" vs. degrees. Thanks for clarifying this.
JC in KC
"Dude! He did, like, a total 360 and got pointed the other way."
Oh no, he didn't. Why do they keep saying that?
Last edited by hotshoe36; 01/13/2008 3:25 AM. Reason: none, really. Just mean-spiritedness, if that is a word.
1951 3800
-hotshoe
